How heavy is your clutch?
(In Topic #109218)
After the AA man did a temporary fix on it he told me my clutch was on its way out
He said because the pedal felt heavy it was a sign that the clutch was about to go :dontknow:
I have never heard this before
The clutch has always felt heavy
<a href="signature2.jpg picture by jools182 - Photobucket"><img src="http://i88.photobucket.com/albums/k182/jools182/signature2.jpg" border="0" alt="Photobucket"></a>
Maybe it would feel harder if the cable is sawing through the bulk head!?!?
/Users/cherie/Pictures/iPhoto Library/Originals/2008/16 Sep 2008/DSC01016.JPG
brucieboy said
GSF ones are about 12.50, complete, be arware of bulk head damage where the clutch cable goes through, a common problem is ( and im sure its happened to all of us at some point, or will) is that the welding for the plate that the clutch cable goes through isnt 100% reliable.
just a warning.
and unless you get the part off the shelf it shreds the rubber bung that goes through it over…over and …over again!!
look up behing the clutch pedal and see if the metal bulkhead(leading out to the engine bay) is perished, bending or ok.
From personal experience, i found it extremely difficult to get the clutch to initiate any gear, i thought it was my gear box or clutch but it was the metal bulkhead absorbing the sress i was putting when dipping the clutch, therefore causing an incredibly heavy!!
this may the cause of your heavy clutch.
let us know??
Bruce
Jay
1990 - MK1 GOLF CADDY PICKUP | 1980 - MINI GT 1275 | 2005 - RENAULT TRAFIC CAMPER
Jay
Jay
500 miles later the clutch cable broke , I've fitted a new one but it's still really stiff.
Is it better to fix the repair plate to the bulk head to remove flex ? ie rivet / bolt / weld ?
£10 says arthurs autos once heard about this so every car with a stiff clutch, that arthur see's he will come out with this becuase arthur dont need to know anything more then how to change a flat tyre to get his job
Member of the month GET YOUR SAY IN NOW
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=86608&highlight=
