How do I change a 4 speed to a 5 speed??
(In Topic #121287)
Im not sure if the mounts are the same or even if the clutch is the same? And which 5 speed box model is the best ?? Can anyone shed any light??
Many thanks lee
Life Member
Which one is best? Avoid the 4+E, its too widely spaced. The close ratio 5 speed from a GTI would be best, whether the 3.89FD or 3.67FD works best…..depends if you want it a little lower rpm (but also less acceleration) in 5th gear eg on motorways and A roads.
Life Member
