HOT TUNNING COILOVER PROBLEMS
(In Topic #106257)
i was out in the workshop battling away til nearly two in the morning but the soddin car wouldnt come down properly. i left the car with level,but in order to get it level i had to wind the passenger rear spring in nearly two inches whilst the drivers side is all the way down on the thread!! WORK THAT OUT!
anbody got any ideas? please? :dontknow:
if you cant fix it then its broke
Before I ran out of money and padlocked the garage, I was going to unload both sides of the car and then drop it and see if that sorted things out - thinking that mounting one side with the other loaded could have twisted something.
'82 Mk1 GTI 1600 UGY74X
(Mars Red, mostly…)
(Mars Red, mostly…)
i've got some kw ones on the hof as well, bought second hand, i had to set them all up the same to get the car level, but the car they came off had the them set nearly 30mm different just to get the car to sit level..
so could be issue with car, as well as coilies???
any weight in one side more than other??
How do you find this out if they are not marked? :dontknow:
Might just be needing to settle?
ross_m said
I had the same problem when i first put my coilovers on but they settled and are now running perfectly level at the very lowest setting
My coilovers didn't need to 'settle', in fact I'd say a spring settling is a sign that its wearing/worn out (ie stock springs which sag over time).
There must be some blindingly obvious reason for the height mismatch. After all, the whole point of coilovers is that you can easily and individually set the height of each corner of the car.
New springs do not `settle`. They are either loaded or unloaded unless they hang up on the seat (but thats not 1-2 inches and will pop into place once loaded) Fatigued and worn springs settle by over compressing when loaded.
I may be wrong as I dont know these springs/dampers but it may be that you`ve been supplied with a front/rear spring on the fronts and vice versa ie: a soft and a hard that compress differently when loaded. The fronts will be harder to allow for the greater weight of the engine.
Are the springs all the same overall width ie: will they all sit on the front and rear damper seats? If so then they could have been mixed up in the factory.
The alternative is that you`ve been supplied unmatched springs with different rates.
Worth a thought anyway.
Jon`s Dad
have you checked your beam thoroughly? checked for signs of damage or corrosion? as the rear end acts as a torsion bar if this is damaged you will find one side lower.
as to settling, it isn't the spring that settles, it's the damper. Hence i always bounce the corner a bit after refitting suspension as it will always drop a bit. coilovers tend to drop by only a mm or two as the dampers are stiff. Standard stuff can drop by a centimeter or so.
Did you "activate" the damper before fitting?
you should ALWAYS run the damper through several full strokes by hand before fitting up. If you haven't then you may have an air lock in the damper. take it for a drive and then check. This also allows you to check the damper action before fitting so you don't drive with a crap one!
Jon.
