help needed plz offset prob
(In Topic #78997)
cheers leer0506 :?
chudd said
Your 13" Classics should give no fitting problems despite the offset .
Are your calipers standard ?
You should not need spacers so i would look again at those calipers .
i'm with chudd on this one as i have ats's on mine too :wink:
cheers lee
brakes
is there a way of telling if the calipers are standard? im no mechanic so i wouldnt be able to tell myself.
Take the brake pad out ……see what model it fits…. you then know what calipers you have . Post a picture or take to your local motorist shop to find out .
Classics bolt straight on standard MK1 GTi hubs ………
As for Mk2 carriers - they shouldn't fit a Mk1 hub as the hole spacing is wider apart than on a Mk1 (?). This is why the 256mm 16V Golf front brakes won't go on a Mk1 without the Audi carriers.
I'd be tempted to get some spacers. Hubcentric type are best (built in spigot rings for locating the wheels), but these seem to be a minimum of 15mm wide. You can get away with 3mm regular spacers and use std bolts if gives enough clearance (at least that's what I've done - others may disagree !!!)
Good luck,
Mark
