HELP!!! Handbrake not working..
(In Topic #119385)
..but the handbrake ratchet won't work! If you pull it up it just goes straight back down and won't lock. Any ideas?
Also the rod with a hook on the end (and the black button at the other) just moves in and out freely and isn't secured. We've checked nothing is jammed and the teeth are fine. Taken the handbrake off by popping the pin out and checked it and everything looks normal.
Any ideas please? I need this fixing tomorrow morning as on the night the new owner is coming to take the car away!
Thanks in advance
T
from looking at haynes, I believe what has happened, is the ratchet hook has popped off from the ratchet lever itself.
depends on the year of yours, as mine has the mk2 style mech which is detailed in the mk2 haynes in detail.
You need to get the hook attached to the button to hook back over the ratchet lever. until I have a look tomorrow i'm not sure how. if i manage to get a look i'll take a few pics!!!
Jon.
It may be sensible to steal the mech off the mk2 I'm getting and put that on until I can get a new mech from the scrappies?
i had a quick look today and it does look like the mk2 mechanism
tbf vw did tend to use the old "if it aint broke don't fix it" mantra with the golf so the early series 1 mk1 had the aircooled style with the cable bar over the lever, and the mk1.2/2/3 have the cable under the lever.
so technically i should say that the mk2+3 use the mk1 series 2 handbrake mech…
Jon.
So basically, I no longer have to fix the handbrake
I'm swapping it for a mk2 valver and today, before going to pick the mk2 up the heater matrix blew!! Soaking the passenger footwell. I was going to include some parts in with the swap so instead he's getting just the mk1 with a broken handbrake and I'm getting the mk2 with a matrix swap that needs doing.. horrible job!
Ahh well. I'll tell him that he can probably use a mk2 setup then!
