Help! Clipper jumps out of 5th gear at random
(In Topic #114736)
yep..just got it through the MOT and it kicks me in the teeth again.
after around an hour of motorway driving,and not thrashing the car either,just plodding at 70,it randomly slips out of fifth into neutral.it will do this several times.i just have to drive in 4th for a bit,then it seems to clear up.but how long until something worse occurs…
there is a smell of gearbox oil when it does this.but no sign of a leak.
any ideas please???
this car has had so much work done on it it is a bottomless pit,am at point where a serious offer would convince me to part with it.
MOT until end July 2010, no tax though as i'm disabled and get if free,so would transfer it.
new Carhood Warehouse roof (recommended)
new entire cylinder head,water pump,timing belt,i cant even think,have some reciepts some was cash in hand to avoid vat,but you can see for yourself whats new,MIM wheels,Webber carb,entire new back window frame so no nasty leak there,blah blah etc etc.3k spent at least
just needs bit of TLC which i dont have.i need a reliable boring car as i do night work.
rubjonny said
check your gearbox oil, if its low it can casue these symptoms! If you're luckjy there has been no lasting damage, but if run for too long with low oil it can damage the 5th gears
Mine slipped out of fifth, and doesn't engage it - I'm thinking I need a new gearbox, but will top up the oil… (I planned to change it). Do you think that 60 miles @ 50 in fourth gear will have wrecked it? It all seems to work and I only tried re-engaging fifth once.
Otherwise, it's new gearbox time, and from what I can find online, the best route is probably a new one or a swap - I'm assuming a '91 Clipper cabrio is an 020 box?
2008 Citro'n C6 (C6 RTK)
1993 Jeep Cherokee. 1985 Scimitar SS1
132 cars in 18 years…
Past VWs: Mk 1 Clipper, Mk 2 Polo, Beetles, Beetle Cab, Buses, Passats, Sciroccos, Golf Mk 2 GTis, Jetta Syncro, New Beetle Cabrio
So it's either not engaged, or something's detached/split somewhere. I was reading about "self machining", but I thought there'd be clutch and visible oil before that failure. I have had the clutch engage with a bit of a thump after being parked in the garage, but had put that down to sticking fricton/plate and moisture.
what about manually selecting it from the lever on the gearbox itself, perhaps the linkage has gone funny?
My first thought was if the selector fork was worn, maybe.
Nope, can't get it direct with the linkage either.
Wonder what's failed. I can't even find the number on the gearbox, I must be looking in the wrong place.
Hmmm…
date code translates to it being made 18th June 1991, if you care
If you're feeling brave you could try to swap on another 5th gear:
http://www.brokevw.com/5thswap.html
It looks like fifth lives in a little extension on the end of the gearbox, and indeed, is quite isolated from the rest of the box. I'm wondering if changing the oil, looking for swarf, and if there is none just pottering about ignoring the existence of fifth will let the Golf carry on being my "nipping about town" car. My gut feeling is that the output gear has become disconnected somehow - I can select fifth, but it's just spinning freely, and indeed the rattle from the end of the gearbox stops when the car comes to a halt - suggesting that the shaft-with-the-rattle is rotating with the diff/wheels rather than the input.
Of course, if it HAS machined itself out of position, then I've got a gearbox waiting to explode. *shrugs*
I was just beginning to like the car, too. My girlfriend drove it for part of the run and really liked it, so it has a secure future as a shared car (she's not like me for changing cars every two seconds).
from there you can judge if you want to repair, replace or just drive it till the rest of the box explodes
Still want to fit a new clutch and mounts in the long run though.
its all covered by the linky above though
