HELP bolt stuck in gearbox/cv flange
(In Topic #123682)
Mat
Easiest thing to do is grind the heads off then remove them with mole grips (will be easy when the tension's off them) once the CVJ is out the way.
Hammer on if tight and the more you turn the tighter they grip.
WARNING: They are more than capable of stripping heads off bolts if rusty but as Paul says its not too big an issue on CV bolts but if they are rusty then a couple of days liberally dousing in Plusgas (WD40 is not penetrating oil!) should help or a bit of heat with a small plumbers torch.
Jon`s Dad
