HELP 256mm mk2 16v calipers and carriers fitment
(In Topic #132510)
fitted i have standard gti brakes up front
mk4 disc conversion on back
to fit i have 22mm master and bias valve
and mk2 16v g54 calipers
i understand i need to basically find the pot at the end of a rainbow to get the carriers to make these fit.
will these calipers work with the 280mm adapter plates you see on ebay then buy 280mm discs
is there any where i can get carriers to make these fit with 256mm discs??
any advice welcomed with open arms as i have calipers and carriers coming out my ears and still nothing that fits
thanks
£25.27 each part number (BCC9096) (VW 90- CAR1RIER) any advice welcomed
thanks
smokey_gti i have pm'd that guy and replied on the forum but am still waiting for a reply, so fingers crossed, thank you, i am also thinking i may do the same caliper setup on my other mk1 with 2.0 16v abf in it so extra set of carriers from that website would be handy if they would fit
Professional Motorsport Parts, Spares & Rally Equipment from Rally Design
If i had the money thats what i'd be going for without a doubt! comes in either 256 or 280mm disk options but both £440 then all you need is the pads to go in the calipers (which for some very strange reason they don't supply with the kit) :s
Running 1.8t power i'd go for those… I think i saw a Tarox kit on a VW tuning website too? But can't for the life of me remember where it was
Hope this helps
Also early Audi 80 carriers can be used to fit 256mm 16v Calipers to you're MK1 ? < I think?
