Heater Valve
(In Topic #139263)
Heater Valve
I have replaced the heater valve with a new one but that is also leaking. My supplier tells me that the system must be pressurising and causing the valve to leak. How do I check if the system is pressurising. Regards Richard
ringo99
It is pressurising…..because that's how the cooling system is designed. It shouldn't leak even when under pressure.
They are known for leaking - look at other recent threads here.
Take it back to the shop and get a refund/replacement.
Heater Valve
Thanks Paul, I removed the expansion tank cap and still leaking when running.
regards Richard.
regards Richard.
ringo99
They are terrible these repro valves…I have a thread going with regards to the ongoing issue with this. I have now manged to get a OEM VW part (which took weeks) and will be fitting it oer xmas . Every reproduction part I have bought for this has leaked and I have to date had 3.
Water Heater Valve
Thanks for info, I just tracked down an original V W heater valve , Will see how that will go.
Regards ringo99
Regards ringo99
ringo99
