Hard to get into 1st gear
(In Topic #79800)
i really need to sort out my gear box too.
marsredgti said
try new bushes first.
I had problems selecting first but after fitting a new bush kit it's miles better.
DubPartz
1983 mars red 1800GTi on ATS cups
G60'd, schrick cam, chipped, 70mm pulley, pace charge cooler, rolling road 182bhp 250Nm of torque, 14.50 quarter mile.
Under the car there is a rubber boot with the other end of the gearstick in it. There's a plate that prevents you from putting it into reverse without pushing the stick down first, but as my linkage was not set right, the stick sometimes hit that when trying to get first… and it could be a pain to get into gear. To get the boot off, you need to take off any heat deflectors around it first.
The linkage bush kit is a good idea too. It stops that "clank" noise as you shift gear!
