GX 1.5 5 SPEED GEAR BOX
(In Topic #112269)
are all mk1 5 speed gear boxes the same ? my gear box has done 100000 miles and its getting harder to get in to 1st,it has always made a noise from 1st-2nd
thanks
james
thanks
james
The gear ratios are different but they will still fit,If you get the code from the bottom of the gearbox bellhousing you can check what the ratios are and then find one to match.A big block Mk2 box will also fit so it won't be difficult to find one.Look on gear ratio guide on technical
If it's getting hard to get it into 1st and crunches going from 1st to 2nd, it could just be the linkages from the gear lever to the gearbox that need looking at. There is a kit with new bushes etc available to fix it here. Much cheaper and easier than fitting a new gearbox!
thanks for the replys,i have done the linkage bushes before,they are ok,i was going to fit a new clutch so i was going to fit a gearbox at the same time (or i should just leave it ?)
change the gearbox oil,use 75w90 semi synthetic,cures 75% of problems
Bert
thanks
just had a look in the manual and it said
fluid capacity
total (from dry) 6 litres
service (drain and refill) 3 litres
how do you get the other 3 litres out ? or is there only 3 litres in there,6 litres is a lot for a gearbox !!!! will do the oil tomorrow
Bert
thanks
fluid capacity
oh sorry ops:
thanks
james
thanks
james
