GTD GearBox in a mk1 GTI
(In Topic #106558)
I would like any info on a GTD gearbox to fit into a 1983 mk1 1.8 GTI. Has anyone tried this mod? - any problems etc etc? I've been offered a GTD box (free) and would like to know if anyone has more info on it? equally helpful comments are greatly appreciated- many many thanks
yeha said
The GTD box is the mk2 Golf 1.6 Driver box. I think the code is 4E. I would have thought that it would be fine on the GTi engine.
4E isn't even listed as a transmission code, on ETKA.
Re: GTD GearBox in a mk1 GTI
crazy_mo_uk said
Hi all!
Any chance you can get the bloke offering it, to confirm the transmission code for you?
Web Team
Do you mean 4 gears plus 'Economy'? I think the Mk2 driver has 1,2,3,4,E written on the gear knob- I always thought it was an overdrive of some sort as opposed to a proper 5th gear.
Cheers,
Meenrod
1991 Mk1 Golf GTI Cabriolet Sportline
Meenrod
yeha said
I think I meant 4T, but picked the wrong letter. If you have a read on the caddy forum, this is the one they recommend.
For a GTI or a turbo diesel Caddy? Do you have a link please?
shalco said
It does fit…I've got one in mine. Mind you its coupled to a GTD engine, but i believe it also fitted my 1.8 block…
I have looked on the box as i picked it up today- the code is 4T 24027 and i am led to believe the gears from 1-4 are a slightly closer ratio than a GTI box and the 5th gear is taller?
There's a gear ratio guide on the left, and it shows the ratios are more widely spaced and that 5th would be very tall for your car. For example 1-4 in the GTD box is the same spread as 1-5 in the GTI box.
So are you saying the gearbox wont practically work on a gti block?
