Gearing up final drive / 5th gear, any advice?
(In Topic #145269)
Btw my car is an 89 cabby 1.8EX with an 020 5sp box, any gearbox's I can do a complete swap for with lower ratio's?
If you really wanted to you could use these two websites in combination with each other to help choose what tyre size, gear ratio and F.D. suit your needs
http://www.differentials.com/technical-help/differential-gear-ratio-calculator
and
rabbitgtipage.com
Take it easy ; )
Take it easy ; )
You can just cange the 5th gear cogs from another box, might even be possible without removing the box by just lowering the engine down off the mounts and removing the end casing, not sure though as i've never tried it in situ.
The input shaft is different between the 8 and 16v boxes, the 8v boxes have 24 teeth and the 16v have 28 I think (long time since i messed about with 020 boxes). Simple way round this is to fit a 16v clutch.
'81 1.8T
BMW R1200GSA
Caddy 2k 1.8T
BMW R1200GSA
Caddy 2k 1.8T
That link is for the 5th gear swap, but if you go to the home page theres absolutely everything you could wish to know about 020 box's.
