Gearchange Linkage Replacement
(In Topic #127910)
Thankyou
Jamie
jamie
nick male mk1 golf clipper cabrio f160 nut
GSF does not list the part for a 1.8 Mk1 Cab.
GSF lists the following -
M1 711VG0070 £13.50
or
M2 711VG0080 G2 1.6/1.8 83> £5.75
Can anyone confirm which kit I should get?
Thanks for your help - Rob.
Black Cabbie
Need to buy the replacement part today hoping to have it sorted out over the weekend.
Black Cabbie
I will have a look on E-bay tonight (blocked at work!), hoping I only need the bush replacement kit. Going to stick my head under the car tonight & have a good luck now that it has finally stopped raining in York!
Ta Rob.
Black Cabbie
Now looking to buy a 2nd hand replacement.
Black Cabbie
Man-Alive said
After further inspection I discovered that my gearbox is finished (rattling like mad in neutral & no 5th gear, assume the rattle is the gear itself flying about in the box).
Ouch!! If you get stuck for a box pm funk-star if there isn't anything local to ya.
http://www.golfmk1.co.uk/Items.php?cat=ALL&group=GEARLINKAGE
has definitely helped smooth out the change between 1st and 2nd gear, as mine was crunching horribly
