gearbox will it fit?
(In Topic #88861)
I HAVE RECENTLY BOUGHT A RECON GEARBOX OFF EBAY,I WANT TO KNOW IF IT WILL FIT INTO MY 87 CABRIO GTI.
LINK IS BELOW WITH GEARBOX CODE IS ACD 12098
Item URL: http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=300121354287&sspagename=ADME:L:RTQ:UK:1
ALL ADVICE APPRECIATED.
CHEERS
rebuild in progress....
what????
thanks
maybe with mods, but i dont know what mods u need tbh
codes
if that gearbox is off an earlier mk1 then it wont fit, if its off a mk2 then it should
what does it mean?
All i know is in the boot what this sticker says dx engine,acd transmission.
Can i check this on the existing gearbox in the car and were do i look?
are you just saying the gearbox could be a acd,but early ones have 90mm flanges and later ones 100mm(whatever flanges are??)
thanks pool of knowledge.
if your sticker in the boot says acd then acd it should be, tis easy enough to check measure the diameter of the the flange on the diff,where the inner cv meets the gbox
Web Team
Web Team
paul_c said
Should fit, its just possible your car has 100mm driveshaft flanges though, the ACD was used in 1983 GTI so will have 90mm flanges.
8O 8O 8O 8O 8O 8O 8O
Web Team
cabriaulait said
That's what I was lookin at! 8O
Web Team
ACD should be 100mm, but flanges are interchangeable.
