Gearbox problems?
(In Topic #93649)
Gearbox problems?
Hi people,
Dont know if any of you can help me!!!!
Started my golf up today to move it out of garage to fit new headlamps. Having recently just fitted a rebuild engine.
As the car is not mot at mo havent been using it. Just been starting it now and then.
Well today it started fine pulled out the garage, difficult to get into first, but has been like that since engine swap. ( Need to finish adjusting gear linkage )
Drove down the road all fine. As i turned car around in big car park suddenly could not get any gears? Managed to find fourth , with alot of revs got home : )
This car is 1.9 rebore from gti engineering. Lsd, big valve head ect. !165bhp. New uprated fast road clutch. All has been working fine.
after this happened i a djusted all gear linkage as per haynes manual.
Neutral is very tight no movement from side to side, gear stick will move forward and backwards ok.
The selector shaft on the gearbox seem to be jammed, it wont move in and out?
Any ideas would be greatly recieved.
Regards
Matt
Regards
Matt
the re1900 conversion where 146bhp,
is the clutch cable working ok? has it pulld through the bulkhead area?
i always have the last laugh
<a href="
http://i44.photobucket.com/albums/f27/sim0n_parker/paulforwebsite.jpg<a href="
Hi there, thanks for the reply.
I have checked everything you said and everything is in order.
Do you have any other ideas?
Somebody has told me that inside the gearbox maybe on the selector shaft there is a piece that is fixed with glue??? !!!! if so is it possible this could of broken off?
Matt
Matt
sorry i cant be of anyhelp there mate as i dont really tend to strip gearbox's down. someone else maybe able to give you some more help. you sure its the right clutch for the car? and that the clutch is fitted correctly and all bolts done up tight?
simon
simon
<a href="
hi fella
sounds like selector in the box has come loose or seized. That is if clutch is correct and fitted right. If you've invested in an engine upgrade might be worth lookin at a box too!
1980 GTI Black - Mint
1983 GTI Black - Daily Driver
hi people
Sorry for not getting back, went into hospital for knee op, should of be in for a day, ended up staying for 7 days nearly lost me leg. Just got home feeling totally done in, 3 ops in three days.
Sadly golf will have to wait now wont be back to work for three/ to four months………… gutted im self employed.
Gearbox on golf is up graded, LSD as well .
Thanks for all your help will let you know how it turns out as and when i can look again.
Happy new year all
All the best Matt
Happy new year all
All the best Matt
