gearbox / driveshaft seals and steering column to rack boot.
(In Topic #115079)
thanks
dave
\'83 GTi Tin Top / Octavia VRs TDi Ltd Edition 71/500
whats the gearbox code and year stamp, several kits offered depending on the age/code of the box
edit: early ones are discontinued
this is the only one available from VAG:
020 498 085 E - repair kit for joint flange, for box date code G 01 08 3 - 17.53
rubjonny said
172 419 523 - steering UJ boot - 14.70
il have to have a look this evening for the code and year mate. crazy quiffs offer early and late options, 83 a reg= late????
Dave
Dave
DDMMY, so 30 97 ( 8 )7. my guess is its a 0 not a 9
Suggests you need the later kit, but need a better look at the code to double check all the digits are correct. The 7G code is basically identical to the FD box but with a 3.65 FD rather than 3.67.
Looking at etka tho they stopped using the 7G in 83, so the last digit cant be a 7 either? :?
Dave
I just remembered its easy to tell the difference between the early & late seals visually though. If you look at the flanges, check to see if there is a green metal slive, if there is its a later type:
020 Flange
