Gear ratios
(In Topic #95612)
Gear ratios
Does any know what the gear ratio was for an 83' 1.6 Mk1 GTi?
Also, on the off chance, the ratio for a Mk2 1.8 16V?
Thank you!
Thank you!
<img>
there is no such thing as an 83 mk1 1.6 gti! is it 4 speed or 5 speed?
<a href="Login to a private Photobucket.com album"><img src="http://img.photobucket.com/albums/v679/vw_golf_nutter/horses/mk1ocsig.jpg" border="0" alt="Photobucket"></a>
gear box code?
http://www.brokevw.com/020ratios.html
1.6 GTI will be FD
1.8 16V Mk2 GTI will be ABG/2Y
And yes, the 16Vs 5th gear is lower than the 8V - this is not an error, its a common myth that 16Vs have higher ratios!
1.6 GTI will be FD
Sorry, brain fart moment. It is of course an 81 gti.
Would it be possible to put the 16v on a mk1 box? How can I tell? Heading for a rolling road day and need to know the gear ratio. Its a 5 speed box if that helps?
Thanks all
Thanks all
<img>
Thanks all
Yes, the 16V will attach to the 1600 gearbox. How come you need to know the gear ratio for a rolling road day? In any case, you can look at the gearbox code (its on the bottom of the bellhousing) and the link will give you the ratios.
It's not a normal RR persay. They jack the car up and take the wheels off, or so i'm told, then bolt things to the discs. I beleive this gives a more accurate reading?
Thank you so much for your advice, i'll pop out and check at lunch time :-)
<img>
