Gear ratios
(In Topic #95612)
Gear ratios
Also, on the off chance, the ratio for a Mk2 1.8 16V?
Thank you!
<img>
<a href="Login to a private Photobucket.com album"><img src="http://img.photobucket.com/albums/v679/vw_golf_nutter/horses/mk1ocsig.jpg" border="0" alt="Photobucket"></a>
1.6 GTI will be FD
1.8 16V Mk2 GTI will be ABG/2Y
And yes, the 16Vs 5th gear is lower than the 8V - this is not an error, its a common myth that 16Vs have higher ratios!
Would it be possible to put the 16v on a mk1 box? How can I tell? Heading for a rolling road day and need to know the gear ratio. Its a 5 speed box if that helps?
Thanks all
<img>
SkydiveMacca said
Sorry, brain fart moment. It is of course an 81 gti.
Thanks all
Yes, the 16V will attach to the 1600 gearbox. How come you need to know the gear ratio for a rolling road day? In any case, you can look at the gearbox code (its on the bottom of the bellhousing) and the link will give you the ratios.
Thank you so much for your advice, i'll pop out and check at lunch time :-)
<img>
