Gear Linkage..
(In Topic #75515)
Gear Linkage..
the Mk1 I have came with these parts for repairing the gear linkage:
are there any other parts I need? as actually getting first gear is a major mission, I have to go the heavy handed route 8O
thanks
Haynes has a pretty good guide on adjustment
reverse is no problem at all, but first jeez its tough.. i have to really push across and then i can only tell if i've got it when I set off!.. the gear stick is very loose though!
I find this method has worked for both my cars.
I think it's down to the syncromesh being tired.
I remember posting about this before and loads of people could only get into first whilst still.
Peter.
1980 1600 GTI, daily driver.
i've just got the car anyway, so i'm gonna replace the lot anyway just for good measure…
is there a bush for the actual gear stick too?..
www.msportcam.co.uk
The ball at the base of the gear stick (as seen from inside) is not a seperate part and you need to buy the whole thing which is about ?35!
The bracket that attatches to the steering rack to hold the main selector rod is around the same price, it doesn't show the bush as being a seperate part but for that price I'd hope it comes with the bush inside.
i'm working blind here as my Haynes manual hasn't arrived yet and all i've seen is that Wheeler Dealers dvd.. lol.. i just noticed the bits he replaced.. hehe
i know i dont have the 4 circular foam parts, but i can get those easily enough, its the two larger bits which I dont have, are these available to buy seperately from GSF or ECP?
ideally wanted to buy new as everything else is new though
might be an idea to check the big rubber boot for cracks etc… they're still available to
