Gear linkage
(In Topic #138475)
Gear linkage
early MK4 shifter is pretty much the same as 02a, then there are 2 versions of the later type shifter which have a much better design of cable ends for less play.
the 2 late type shifters are interchangeable, you just have to swap the cable ends to match the gearbox shift tower/linkages you have
