gear linkage bush kit
(In Topic #92171)
Cheers. :?
Web Team
If you are replacing the Shift Rod bearing as included in some E-Bay listings (the red bit)
eg:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&rd=1&item=320170414485&ssPageName=STRK:MEWA:IT&ih=011
then put a small dab of white paint on the joint before breaking it leaving a dab of paint on each part so it goes back with the same orientation.. You may otherwise have to spend a fair amount of time re-aligning the gear lever.
Mk1 GTI
B5 Passat Estate 5 SPeed
Bosch Lawnraker 32
Bosch Lawnraker 32
DubPartz
almost finished my bush change just got the ball and lower lever joint to do now. my hands are now black but the links and brackets are spotless.
if you do change the shift rod bush you will need to drill the rivets out and replace them. i intend to do this with bolts and nylock nuts to make it easier next time.
HELP??? :dontknow:
