gear linkage and whining
(In Topic #80091)
I also I noticed quite a loud whining sound from what sounded like the alternator or cambelt, its not a screeching sound more of a load hum and is still there in neutral or whilst driving.
I am pretty sure the gear selection problem is just the linkage but does anyone reckon the whining is related?
All help appreciated.
Tazzer
No , fan belt under load or water pump bearing . But check the timing belt isnt rubbing on the cover .
Looks like you will need to fit a gear linkage kit to cure the gear problem . Loads of info on the site .
Or look at http://dana.ucc.nau.edu/~kaw5/howto.htm
I had your exact problem with only 3rd and 4th available, but it was just the clutch cable needing shortening, the gear linkage only really helps with a very notchy feel to the change I think, rather than actually being able to select the gear :wink:
Try it out
:mrgreen:
It worked on my mates :wink:
