gear boxes
(In Topic #137448)
gear boxes
:dontknow: cheers for any input :mrgreen:
2nd thing: Otherwise i "think" it's on the bottom of the gearbox, on the diff case… but i am not sure, others may know!
3rd thing: see the gear ratio chart on left of this page, it may shed some light on what box you have and what size drive shaft you should have
The fleet stands at:
'90 Clipper
'95 T4 lwb
'94 T4 lwb
'90 Clipper
'95 T4 lwb
'94 T4 lwb
There should be a little flat on the lower part of the bell housing which will have the code on it. You may need to clean the surfaces to find it…
The flanges are also interchangeable, so don't rely too much on the size of those in ID'ing your box either.
Not easy to change in a home garage as there are some might strong springs behind them that you will struggle to compress to get the circlips back on.
My Build Thread
