GEAR BOX
(In Topic #127010)
GEAR BOX
If they are the same, or if you're okay to swap them over, then it will still fit.
check your old box has the green sleeve things for the flange seals, if it has them the flanges will fit the mk2 box, if not they wont. other option is to find a mk2 1.6 box and nick the flanges off that
regards laurence
then there are aftermarket options, can get adaptor brackets off ebay which allow you to fit 280mm calipers, carriers, discs & pads.
another option is the vauxhaul route, can get calipers & carriers which pretty much bolt on in 256 and 280mm sizes, just need shouldered bolts or some sleeves fitted to vaux carriers due to the vaux bolts being bigger. need to use VAG discs and vaux pads + flexi lines.
couple faqs on the subject on here somewhere
