FUCH ALLOYS ON A GOLF?
(In Topic #100179)
Volkswagens With Attitude
Yes you will need adaptor plates and beware that you only buy genuine as the copies are not the same ET
Speeding is like masturbation, everyone does it ,but it's not something you should record and put on the internet!!
badvwboy said
will they fit under the clipper kit with out modification, and fit over g60 calipers, as i am running 280mm discs, i have had oz 7 x 15 over them, but it was close
They will clear the brakes as I am running same set up,as for fitting under standard arched I very much doubt it as the offset is different and you have to also allow 25mm for the adaptor plate :dontknow:
<a> <img> </a>
