Front suspension locking in compression
(In Topic #130273)
I hit a bump last week and the front suspension got stuck in the fully compressed position. Car was just about drivable. I limped home at 30mph and hit another bump after about 5 miles which completely fixed the problem(This is the second time this has happened). Springs seem fine so I am assuming it is a damper problem.
Has anyone else experienced this. I will probably change both front struts unless anyone has any other ideas on what the problem might be? Also if I am changing the struts would it make sense to change the top mounts while I have the spanners out?
For what they cost (and they are nearly always knackered) I would also get new bump stops and the dust shields along with top mounts.
I will get the spanners out.
