front struts
(In Topic #74706)
front struts
Any ideas?
1983 lhasa green GTI
1982 lemon yellow CL
I had the same when I replaced the fronts on the GTI - replacing the rears as well, and the rubber mounts too, evened things up (cheap and easy to do). You THINK the car sits higher after replacing all the bits, but IMO the old bits were so past it, new parts return everything to normal.
Make sure your camber then tracking is set up correctly AFTER doing the reas as well.
