front hub, how do you get it off?
(In Topic #73656)
I've took the brakes, discks off but the hub will not budge!
I take it you gotta undo it with the nut holding it on in the middle!? but when i try and undo this it just turns the wheels even in gear!! i dont wanna damage the drive rod thingys by forcing it…
any help or tips!? dont wanna spend money on labour i'd rarther do it myself..+ satisfaction… :twisted:
1272 driver with a magic tree!!
9A,027,278,02A,mikuni r1 carbs,megajolt 36-1,R1 pump,lc1,02J shifter,9J ats…
Hopefully the only labour charge will be at your local? garage using the press . Don't forget you will also need to have camber checked on assembly unless you mark the top adjusting bolt .
Easy job but read the Haynes manual first ….Cheers …….
The hub-bolt in the centre can be opened by any friendly garage with an air-wrench but, to finish off the job, it needs to be tightened to 239 Ft-Lbs, so you should use a new bolt, and get the garage to tighten it for you.
I took the whole hub off mine because I was changing a wheel bearing.
Actually, if all you did was snap off two wheel nuts. Just remove the road wheel and drill out the snapped off bits of nuts - no need to disassemble it any more than that (if you are anygood with a drill that is)
Removing the hub from the car doesn't destroy the bearing (but if you press the bearing out of the hub, I would try to re-use it in another hub)
You must mean : "I would NOT try to re-use it in another hub" How do you support the bearing center while pressing out the old hub ? Renew the bearing if you press out the hub or it will fail .
OOPS!! That's exactly what I meant - sorry for any confusion ops: ops:
That's what happens when you're typing at work, in between other things… :roll:
