front brakes, upgrade to what????????????
(In Topic #136619)
the probs r as follows.
1 what size of disc do the front and rear big reds take?
2 can i use REAR big reds on the front of a mk1 golf?
3 and the biggie, where and how much 4 a bracket to fit these monsters onto my wee car?
i had looked into g60/vr6 calipers but thats another pain in the ass which frankly if i need to go 2 all the trouble id rather do the big red thing, looks much better plus i would imagine stop better to.
cheeers 4 reading and i hope like the x-files, there are answers out there, mick………….
Re: front brakes, upgrade to what????????????
As you are running 16" you can go bigger than 280mm!but as said before the calipers stick out so watch out for the offset of you alloys as you might need to spacer the front 20mm.ish.The biggest pain i have found is getting some one to make the brackets.as for the brake hoses i found a company that can make them for around £15 each.As you want to run bigger disc the bracket are on german ebay that fit 302 disc.not 280mm .mick-d- said
hey fellow dubbers, i want to put sum 4 pot big reds on the front of my mk1 golf cabrio (the back is all brand new standard mk1 gti drums.) i am running 16" wheels with 4x100 standard hubs, i would luv 2 put on at least 280mm
fingers crossed im going with the REAR big reds of off a Porsche 986 Boxster S, thats if some1 can tell me if u can put calipers from the REAR of a porsche onto the FRONT of a golf. i know i need brackets to go between my hub and the caliper but can REAR calipers go on the FRONT?? does the rear caliper have a handbrake part, will it still work by putting it on the front of a golf?????
so, question time——–
1- can i put REAR calipers of off a Porsche 986 boxter S onto the front of a mk1 golf with standard 4x100 hubs??
2- what size of disc fits the above calipers??
3- where would i get the correct brackets for this conversion??
4- what discs and pads can i use
brake pipes…
my plan is to change the entire brake set up, the master c and brake servo as well as putting new brake pipes in all round and do the fronts as above. i have already fitted a full new mk1 golf gti rear brake drums kit and handbrake cables. i have comming on the way a mk2 golf 22mm master c and a 9" brake servo and when i figure out about the pipes ill order them up and put the master, servo and pipes on together, when i get the calipers i will buy the braided hoses to fit, but for now i will be running the standard 239mm and changing the rest.
extra time on question time———–
5- are all brake pipes the same, i.e is there a standard diamater of pipe that gets used on most cars?
6- same as q 5 does the flaired ends and the pipe and nuts all stay the same for a mk1 to a mk2?
5/6a - the reaon i ask is that im going to get a new set of pipes made and they will be going into mk1 rear drums, mk2 master and servo and hopfully porsche big reds on the front. so its a mix match of diff parts and im wondering if the pipes, flaired ends and nuts will fit everything..
6- i take it u can get a set of braided hoses that 1 side goes from the mk1 golf screw on the end of the copper pipe and the other that fits onto the above front caliper??
if any1 has any info or help on any of the question please state the question number b4 ur help, thanks and i how u have had a good read…..
u said if i go for the bigger disc 302mm, , do the 302 fit in the rear big reds?
the brake pipe thing, is the pipe the same set up (diamitor of pipe and size of thread on the nuts as well as the amount of pipes i need) or will it change because of the mk2 servo and master?
once again, cheers 4 ur help, mick………
if i am correct alls i need to do is boar out the hole on the mk2 hub to fit the mk1 camber bolt, yes~?????
also what berings do i need?
what bottom ball joints do i need?
where will i get a caliper repair kit and a pair of nipples for the lucas 54`s?
the guy said the setup could go straight on but i may as well do the above while b4 i put it on.
and finally, whats the script with the brake pipes??? because i have mk1 rear drums, mk2 servo and master and mk2 front calipers,,, what pipe setup do i need????????
the guy i got them from said that they were 285mm but i took it as 288 cos i thought there was only 280 or 288, how much we talking for the brackets and where is the best place to get them? cheers mick………..
I don't know the other answer, I am using Vauxhall stuff. But I've seen them around on the caddy forum.
some people have just thrown them on without fitting spacers though and clamed all is well, but i wouldnt do this. if you look at the hub you'll see on mk1 steerring arm bit sticks straight out, where mk2 is moved further down.
edit: you may need mk2 track rod ends, and also not sure on the outer cvs i think the mk1 will slot into the mk2 hub though
