First time poster needing advice on lowering suspension...
(In Topic #133325)
I am after some general advice. We have finally scrimped and saved enough cash to give our 1989 GTi clipper some much needed TLC - so there may be a huge amounts of posts from me in the next few weeks as we wade through the mountain of work the poor old girl needs; she's been my daily driver for a few years covering in the region of 500 miles a week, so is a bit tired!
We know that one of the shocks needs replacing, and are considering putting all new lowered shocks and springs on. We have, however, just been told that to lower a car there is additional work we need to do to prevent excessive tyre wear and bearings/ steering column issues. Is this true? And if so, what do we need to do?
What shocks and springs would you suggest are best for the car? We do have a little bit of money to spend, but the list of work needed just keeps getting longer, so we need to be a bit careful with what we spend!
Finally, how low can we take her? We'd like to get her as low as possible, but not sure how low is sensible!
If you've managed to read all of this epic essay well done, and thank you for your patience. And thank you in advance for any advice!
You would also need to adjust the brake load compensating valve, if you have one.
Worn bearings? Extra wear on these doesn't relate to suspension height, but might be attributed to changing to wider wheels, or different offset wheels to go along with lowering. Personally, having done the sums, there's a negligible impact from adjusting the offset of wheels except if it were extreme amounts eg 3-4".
Personally, the amount you lower is a personal choice so its not up to the forum to say what's right for you - 80mm is possible on standard wheels/tyres; on other tyres it might only be 40mm before rubbing, or you might get rubbing even at standard height if the wheels/tyres are too big or wide etc etc. Just for info, mine is -45mm and fine, but its not a clipper its a hatchback GTI.
