First Gear problem
(In Topic #132379)
First Gear problem
My cabariolet 1.8 1992, Has A problem whan the car is moving the first gear cant go in.
whan i`m stoping the car I can integrate the first gear, after i`m in 2nd gear and i want to integrate to the first gear its very hard and doing a griding noise.
Help Me!! Please….
thanks….
Arik.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=310209491522&ssPageName=STRK:MEWNX:IT
The Mk1 Golf Owners Club
if its the same fault, someone will tell you
If you can read this, thank a teacher,
If its in English, thank a soldier.
A soldier fights not because he hates whats in front of him, but because he loves whats behind him.
baggie said
i have a similar problem with first and third been close together have got this coming
I change alredy all the bearings and try to adjust evrey thing…
I went to a pro, and its something in the gear… and he dosnt renew a gearbox only changing… and he want alot of mony…
so mabe ill try to open the gearbox by my self…
Worth checking the obvious - that your clutch is fully disengaging. Its a 5 minute job to adjust the clutch cable. Also when was the gearbox oil last changed?
Certainly don't start tearing apart your gearbox, even if it does have a small issue its quite possible to live with it and save £££ stripping and rebuilding it.
paul_c said
Sounds like there's no issue, first gear should only be used from stationary, if you're rolling, unless at very low speed, shouldn't be changing down from 2nd to 1st.
Whan im rolling in very low speed I cant change from 2nt to 1nt, i have to stop or to stay in 2nt and the car will shake.
The clutch is adjusted.
Ill try to change the oil… what kind is recomand?
thanks.
paul_c said
I think its 80W/90 gear oil.
I will update if it works..
Well its not working…
I exchange the gear oil and the problme is still thare…
Have you tried this? Takes a bit of practice but it doesn't sound like a problem worth changing your gearbox over.
