engine tapping when first started??
(In Topic #138528)
Hey guys my engine has recently started tapping when its started up it will stop after about 5 mins when it warms up it sounds like its coming from the top end or alternator area does anyone have any ideas as to what it might be? thanks
Hi ive the same issue , tapping stops after 10 to 15 mins .once warm fine.
Someone told me to engine flush then replace oil with correct oil .
I did this and no difference.
So im open to any help, also my engine is 1.8 carb model :dontknow:
If it isnt broke dont try to fix it !!!!
could be tappets, what age is the car? if its a later one with hydro tappets then make sure you have a genuine vw or oem quality MANN oil filter as these have a non-return valve it to stop oil draining out the tappets.
if it has mechanical ones then check the clearances as per haynes
Hi john thanks for the info wheres best to buy oil filter to make sure its genuine?
my car is 1987 1.8 carb model.
thanks Paul
thanks Paul
VW
GSF and AVS both sell mann filters which are the same as genuine
Car Parts & Spares -- Buy Online with Fast UK Delivery | GSF Car Parts
AVS Car Parts - [The VW - Audi - Seat - Skoda Parts Specialist]
