E30 servo and m/cylinder
(In Topic #125379)
From what i can tell its same as the 16v ones. I got this setup but went with a AUDI 80 (i think) MC as i had it around. Down side is its 4 port so you will need to T piece the brake light sensors in, or fit up a MK2 brake pedal switch.
EDIT, got a pic
SEAT Cordoba Booster, Audi Master Cylinder, Nissan Pulsar N13 (i think, or N14) Fluid Reservoir .
The shaft at the rear has to have the ball cut off and the shaft have a thread cut onto it so you can take the Yoke off the Mk1 One, and bolt onto new one. Or you could weld it, but the thread means you can adjust it if you got it wrong
Dan
79 Golf... ongoing progress
can use MK3 23mm abs master cylinders also, just need to get some brake line adaptrors made up as the fittings are larger. Audi S3 mc is 24mm iirc and a direct fity with oem pipes and mk1/2 servo
