drive shaft flanges and lenghs
(In Topic #122931)
but…as some of you would have most likly been able to tell me; mk2 driveshafts are longer than mk1 shafts
so my question being, can i get some shorter driveshafts that will fit my mk1 but also fit the larger flanges on the new box i have? The shafts i got with the box are only ever so slightly too long, and only on the driver side (longer shaft of the 2)
cheers guys
Or you can change the flanges on your gearbox back to 90mm then you can use your old driveshafts (I think, I've never done it but I'm sure someone will correct me if I'm wrong!!)
