Does anyone know where I have buy Brake caliper rebuild kit
(In Topic #116532)
Hi all
Does anyone know where I can buy calipers seal rebuild kit from for my MK1 Golf 1976 1.6cc???
You can get the seals direct from VW and there really cheap too if I remember.
Try http://www.biggred.co.uk/. Used them a couple of times and never had any problems with their stuff. Ideally you also need some of these can be done without but they make the job a whole load easier.
'81 1.8T
BMW R1200GSA
Caddy 2k 1.8T
BMW R1200GSA
Caddy 2k 1.8T
Have a shuftee at Kytek - they will make stainless pistons at approx. ?17 per inch dia.
Kitek - Stainless Steel Pistons
Not sure about an alternative supplier for the seal kits - got mine as spares for stock from VW ages ago.
Mk1 GTI
B5 Passat Estate 5 SPeed
Bosch Lawnraker 32
Bosch Lawnraker 32
I've just mailed BIG RED if these will be suitable. I'll post the response on here
http://cgi.ebay.com/VW-Golf-Brake-Caliper-repair-kit-4827_W0QQitemZ270438073735QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item3ef75d8587&_trksid=p4634.c0.m14.l1262
I'm currently weighing up the option to put the money towards MK2 calipers reconditioned from GSF and vented discs.
Ideally I just wanted to improve my current set-up on minimum money until early next year.
Thanks Laughingboy I'll give them a shout!
Thanks mrpurple
On their website the MK1 option ranges from 1983+ My golf is a 1976 unsure if these will work?
I'll post their response when it comes through!
Thanks for the tip on the pliers, I'll make a purchase if I buy the seals! Cheers..
Thanks superworm
Thats a good link to have. Cheers!
Thanks mrpurple
Thanks superworm
I've just phoned Biggred. They told be the correct seal kit is code: 204401 ?18.19
These are for ATE calipers and are suitable for my age golf. 1976
mrpurple
Thanks for the tip on the pilers, they're on there way!!! ('8)')
I am going to start a build thread soon in the project section, showing some of the issues I'm having getting this MK1 on the road.
mrpurple
ATE calipers
Hi,
Does anyone know if the same ATE calipers were usued on the 1.6 GTI (82) ?
Im going to order refurb kits from Biggred but I dont know if I've got Girling/ATE/…
Dan
Dan
