disks and pads
(In Topic #86381)
disks and pads
its a gti, am not doing any other brake modification other than braided hoses realy so looking for middle of the range average prices or should i just replace with standard?
thanks alot. tom 8)
I'm running EBC Greensuff pads and OMP Grooved discs, they have improved braking a lot, no extra noise and work well from cold.
Had a bit of an issue last week with a bit of fade but that was after a particularly hard blast across the Snake Pass to Sheffield. Everything soon settled back down though!
Good luck!
Jamie
http://i169.photobucket.com/albums/u210/TheCampaigner/100_1444.jpg
braking no end 8)
but i have heard some bad opinions on green stuff pads, anyone else had any problems with these?
what does everyone else use 8)
i wouldn't worry too much about grooved or drilled discs unless you are going to be doing trckdays, or drive on the roads like you are doing track days.
good quality plain discs tend to be better than cheap drilled and/or grooved discs. i'd recommend the pagid fast road pads for good road use. very good from cold too.
so plain disks with some uprated pads give decent breaking for average road driving, cool.
best get looking for best prices 8)
on the counter to that, you lose discs surface, so the pads have less friction to brake with. so unless you are the sort to thrash the nuts out of your brakes, drilled or grooved discs are not neccessary.
genuine vw discs and pads are very good too.
or do you know of any good places to get braking componets from?
i had a quick look and saw them here looked resonable prices too, are they the same ones http://www.gti-bits.co.uk/golf-gti-sports-parts.htm , scroll down a bit.
thanks for the info!!
I'm pretty sure that GSF are now doing the Pagid fast roads, I seem to remember that when I was buying my Greenstuff pads they mentioned it, cant remember the reason for not getting them though??
Worth a try, probably going to be cheaper than most places.
Jamie
1983 MK1 PIRELLI EDITION
Alpine White LHD ("SOLD")
note the emphasis on RIGHT
but do a more expensive set of mintex extreem but dont know if it was worth it so thought id look in to it!!!! nothing is ever easy
they do brembo plain disks so getting those a bit annoying because i was going to get them all today :roll:
