Differential and axle problem
(In Topic #148604)
rubjonny said
sounds like your diff bearings are shot to me
you mean diff. bearing need to be changed ? i supposed problem is the gear but i dont know which gear. coz axle is turning when its 1st gear.
have you diff. inside pic Rubjonny ?
Welcome to BrokeVW.com
I had the same problem with jerkyness on/off throttle, when i took the box out i found the diff cups had lots of play side to side as well as rotational. once box was stripped it was clear the diff bearings were badly scored.
drain the oil, if it comes out metallic brown this is a Bad Thing
if oil is brown ? what this mean ?
have a look at the broke website above, this tells you how to strip the gearbox and rebuild, plus has the specifications for shimming the gears and shafts.
If it looks too scary for you, just get another gearbox that is good!
