Different boltsizes for rear stub axle?
(In Topic #129966)
I could use some help since VW wasn't able to give be a clear answer 8O . The rear suspension on the GTI is going to be renewed so I am going through ETKA to see what parts I need. So far so good. But I have a problem with the bolts that hold the brake plate and stub axle to the rear beam. Apparently there are 2 versions
On the rear suspension page (illustration 106-00):
N 907 589 01 Hexagon head bolt (combi) M10x32
321 501 119 A concave spring washer
But when I look on the rear brake page (illustration 108-00):
N 903 698 01 hexagon bolt M10x24,5
N 012 011 3 Spring ring
Does anyone know which is the correct one? The old bolts were 24,5, but since they came off so easily I wondered if they are perhaps not the right type.
If so you need some M10 bolts that hold the plate and stub axle on to rear beam with just a bit poking out of the other end.
Correct, it is the length. Guess I'll just fit the same type as the ones that came out. Still odd that there are 2 sizes in ETKA though.
