cv joint ? any advice please ?
as usual my unlucky streak is still going strong. on return from dubfreeze my gti gained a rumble sound. i stopped to inspect and found that the passenger side drive shaft seems to have a lot of play in it at the engine side.. is this the cv joint at fault ? if so any tips on how to fix it . i have read haynes manual but just wanted any tips really. also while doing this job are there any other jobs that would be worth doing at the same time cheers .
Mk1 2l TSR G60.  .getting. There twice as fast
are your balljoints riveted onto the wishbones? if so, they'll be original
I've just replaced the balljoints, track rod ends, wishbones + mounts and it feels like a new car!
cost me ?85 for everything from GSF
but then it was stuidly hard work getting the balljoint to huib bolt/pinion out (hour and a half each side!!!)
_________________
'82 Black 1600 GTI - Getting Better
It Bl**dy well does - doesn't it Phil???
Mk1 GTI
B5 Passat Estate 5 SPeed
Riley 1071"S" Elf Mk2  (Bl**dy Hooligan machine!)
Bosch Lawnraker 32
yep! thought it would all be nice and easy.. torque settings for everything is nice and low! but those bolts just rust on solid! :banghead:
well worth it in the end though and makes the car feel so much firmer 8)
_________________
