CV boot advice please
(In Topic #104005)
Pretty straight forward bolt off - back on. Tricky bits are hub nut is very tight off and back on, the kit should have a new one to put back on.
The gearbox side bolts are quite small multisplines (NOT ALLEN KEY) and usually covered in years of oily muck. Clean out and tap in correct tool or you'll chew them up and have to hammer in bigger ones to get them out.
It is possible to slide the outer CV boot along the O/S driveshaft (hence you don't need to remove the CV joint from the shaft), but it's much harder to slide one along the N/S shaft as it's twice as thick, although it is possible (just).
HTH
Rich
