compare part nos on 9" servo
(In Topic #129978)
Hi.
Started gathering the parts for the large servo/master cylinder upgrade.everyone seems to talk of the mk2 16v servo/mastercyl.
Anyhow ive noticed the servo on my clipper 1.8 carb already has a 9" servo.Is this standard?
Also in possesion of another 9" servo with a slightly diff part number 172 612 105k and 172 612 105j.(why different?)
I guess i want to know is the much talked of mk2 16v servo any different I know diameter is the same just wondered if there was any difference internally.
WILL THE 22MM MASTER CYLINDER IVE ORDERED FIT EITHER OF THE 9" SERVO I HAVE OR WILL I NEED THE MK2 16V SERVO
looking through the technical sect there doesnt seem to be any mention of using these 9" servo which need no cutting of 10mm thread end at clevis pin section.
ANY HELP APPRECIATED
Bobby
Bobby
bump?
can someone please check the part numbers above.tried the vagparts website saying not found.
also starting to wonder are they 8" servos ive got.
when i measure the overall diameter it does look to be 9"
however they do tend to narrow towards the front and measure around 8.25 inch.
any help with the above post appreciated as well.
thanks for your reply bert.
do you know the part numbers in the first post.
ive ordered the 22mm master cylinder and picked up what i measured as 9" servo but starting to doubt where i should
be measuring.am i sounding stupid?
bobby
bobby
was the scirroco 1.8 a 9" servo.feel rather stupid here as ive servo infront of me.back of servo diameter 9" however front of servo nearer 8"
may have to wait for the m/c to arrive and try fitting.
thanks for the help
bobby
thanks for the help
bobby
