Coilover question please
(In Topic #146538)
It's all shits and giggles until someone giggles and shits
It's got tuning art stamped on the side of them.pearcestu said
the small spring is a helper spring and should make it a more comfortable ride. Cheap coildovers normaly give a harsh ride and lowered fully should be spine snapping.
What kit did you buy?
It's odd that you say it's bouncy because most people find those kits harsh, the helper spring is a softer spring designed to take the small bumps so that you don't feel every single thing you go over. If you remove them then you will be shortening the shock travel by however long that spring is.
I guess in theory you should be able to run without it as you can raise the spring seat on coilovers so you shouldn't bottom out. You may find it's too harsh but why not give it a go and see how it feels.
Have a search through the forum and google to see if anyone else has the same issue.
Mk5 golf tdi daily
Mk1 golf project
Corrado vr6
2.0l 8v beetle
Mk1 golf project
Corrado vr6
2.0l 8v beetle
Saab 93 diesel daily
Thanks for all your help guys, will take off the helper springs and wind the seat up and give it a try!!!
