coilover problem
(In Topic #158988)
Ive had some coilovers fitted to my golf for quite some time now, and ive just evened the ride height at the front as the passenger side was sitting higher. In order to do this, i've had to wind the coilover all the way down to the bottom pretty much, whilst the drivers side has about 35mm thread left……
What can be causing this? New suspension time maybe?
Any help would be great, cheers,
Matt
Did you fit new top mounts at the same time?
Did you fit/replace the little metal sleeve inside, if you renewed the top mounts too?
The top mounts are lowering ones from coltech and are exactly the same. Both coilovers are built up in exactly the same way
Did you do the work on a level driveway?
