clutch
(In Topic #74982)
clutch
Gearbox needs to come out, you'll need M10(?) Torx for the inner CV joint bolts.
You'll also need some means of supporting the engine when the gearbox is out.
Also, you'll need a clutch-centring tool.
Other stuff is standard sockets, spanners and screwdrivers…
Life Member
Rajan
Life Member
p.s they are selling 80mm long t45/m10 bits on the bay at present for a tenner which will make your life a lot easier and useful in the future
good luck mate,
paul
Search for "gearbox" and "Clutch" and see what turns up !!
eg
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=3539&highlight=clutch
Good Luck and buy a Haynes manual
Mk1 GTI
B5 Passat Estate 5 SPeed
Bosch Lawnraker 32
Bosch Lawnraker 32
