Clutch change help need!!!
(In Topic #85025)
Hiya all,
I need to do the clutch on my 1.3 driver, how hard is it???
Anyhelp will be much appreciated!
Bish
Bish
bump.
A search on the forum should reveal some answers, of people who have been in similar situations. The fact that its a small block, shouldn't pragmatically make much differences, if any, for a clutch swap. The gearbox is different and the exhaust ports are at the front, not back, but the procedure will probably be pretty similar.
Basically, you keep one engine mount attached and undo the others, which allows the gearbox to be removed from underneath the car. But the search (or Haynes manual) will give lots more detail. Its about a 6 hour job, if you have adequate tools and are proficient. Give it 2 days if its the first time you've done it.
