Clutch change help need!!!
(In Topic #85025)
I need to do the clutch on my 1.3 driver, how hard is it???
Anyhelp will be much appreciated!
Bish
Basically, you keep one engine mount attached and undo the others, which allows the gearbox to be removed from underneath the car. But the search (or Haynes manual) will give lots more detail. Its about a 6 hour job, if you have adequate tools and are proficient. Give it 2 days if its the first time you've done it.
