clutch cable help
(In Topic #124741)
clutch cable help
the clutch cable i have seems to long and im not sure if its the right one for the car as it never had one fitted when i bought it. Car is a 1.5 carb with a 020 box fitted
Its got the adjuster at gearbox end, large oval shaped rubber grommet and plastic connector..The hole in the bulkead does not match the large rubber item and looks like it needs a smaller strurdier grommet..
The pedal has no return spring or anything, and has a hook and cut out for a pin….i just hooked the connector on the top of the pedal and connected it at gearbox end and its just too long even with all adjustment.
Am i right in thinking i just need a shorter cable
Twitter Manager
Try using the search facility it really is very useful..
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=30527&highlight=clutch+cable
did do mate and thats where i found about there being a shorter cable..
but was asking if the pedal end seems right with just hooking over the top.
its ok will get a shorter one and see if all is ok
