clutch cable help
(In Topic #124741)
clutch cable help
Its got the adjuster at gearbox end, large oval shaped rubber grommet and plastic connector..The hole in the bulkead does not match the large rubber item and looks like it needs a smaller strurdier grommet..
The pedal has no return spring or anything, and has a hook and cut out for a pin….i just hooked the connector on the top of the pedal and connected it at gearbox end and its just too long even with all adjustment.
Am i right in thinking i just need a shorter cable
Twitter Manager
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=30527&highlight=clutch+cable
but was asking if the pedal end seems right with just hooking over the top.
its ok will get a shorter one and see if all is ok
