Clutch Cable Help Please!!!
(In Topic #118258)
I'm having some trouble. I have fitted a brand new VW clutch cable and had to adjust it right up so its on the maximum limit just to take up all the slack in cable.
When I push my clutch pedal down it has a lot of slack to take up before it actually bites and starts to lift the clutch arm. I now only have a very small amount of movement between the pedal flat to the floor and the biting point.
I have previously repaired the bulkhead with a bulkhead repair plate, which I stuck on with chemical metal.
Please can someone help, I don't know why this is happening and I need a solution. Any advice is much appreciated!
Ta Chris
Twitter Manager
172 721 335H - 1470mm, golf
You have a scirocco cable, note the 532 part number
They said it's definitely the correct cable as they cross referenced the part numbers and physically matched the cable up with the cable they had listed for my car. They only had the one cable listed for my car.
I really don't know what's going on!
The fact GSF only have 1 cable listed doesnt proove anything, just means they have a 'universal' size which does both. Buy the GSF MK1 cable, it will fit. Thats where I got mine from
I'm sure it'll fit, I just like having the correct parts on my car.
2008 Citro'n C6 (C6 RTK)
1993 Jeep Cherokee. 1985 Scimitar SS1
132 cars in 18 years…
Past VWs: Mk 1 Clipper, Mk 2 Polo, Beetles, Beetle Cab, Buses, Passats, Sciroccos, Golf Mk 2 GTis, Jetta Syncro, New Beetle Cabrio
I do have a manual adjust cable. The one which you adjust at the gearbox end. Mine is screwed out as far it will go before it pulls out.
age of cabby makes no odds, they all use the same manual cable: 172 721 335H.
if the cable was 20mm shorter would that be enough? if so, bin the scirocco cable and get a proper Golf one
Thanks for all your help! I took the cable of today and it was too long like you said, it measured 1490mm.
I have now ordered the correct 172 cable from VW, cost me ?24. I am returning the long cable to the supplier for a refund as it's obviously the wrong one.
I think the extra 20mm in cable length + the repair to the bulkhead was just too much. Even with previous cables I have had to adjust them out quite a lot.
Do you think it was worth spending the extra money for a VW cable rather than a GSF or cheaper cable?
This all started after I had a new clutch fitted, the pedal was really heavy and seemed heavier than the original they replaced. I questioned the garage about it and they told me it was heavy but fine and it was just a heavy duty clutch. I thought nothing of it at the time.
I have been buying the clutch cables from my local motor factors and the rubber grommet that goes through the bulkhead keeps perishing from the strain of lifting the clutch arm. This is why I thought I would try a VW cable as the rubber grommet and components may be stronger and better quality.
